Differntial seals 2002 2500hd 8.1L
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by marklambert61, Oct 15, 2011.
  1. marklambert61
    marklambert61 New Member
    I am trying to change the pinion shaft seal on my 11 1/2 G80 diffrential. I have run in to a big problem and hope someone has solved this issue.
    The seal is too part a female tri lip seal that is in the diffrential case and a male sleeve that in pressed over the back of the pinion yoke.
    Female seal is available any where, however the only place I can seem to get the male sleeve is to by the entire pinion yoke $300 bucks from Chevy direct.
    Not really wanting to spend $300 bucks for a $20 dallor seal!.....
    Please let me know if you know a source to by the parts?
  2. Mean_Green_95
    Wow, thats a shame. Have you tried all the parts stores, eBay, online stores, etc?
  3. Jimmiee
    All you need is the seal. The yoke has a dust deflector but this has nothing to do with the seal and never wears out. Just order a seal and you will be good to go. If however the seal has damaged the yoke then you will need a new yoke. There are after market sleeves to repar damaged yokes BTW.
