Dim LED cargo Light
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by SAGO, Jan 12, 2014.
  1. SAGO
    SAGO New Member
    My first mistake was I bought crappy lights. So I tossed them and I them bought new ones that are a bit more expensive and are a lot brighter (when connected directly to a battery). They work great when I first plug them in but after a few minutes they dim. I checked the voltage and it reads 7.8, when moments before it read 12.3. When I unplug one of the bulbs and plug it back in, there bright again. Any one else have this issue? I'm guessn a resistor inline with a the bulbs.... I do mean the 3rd brake light assembly. Thanks!!
  2. Pikey
  3. SAGO
    SAGO New Member
    You wouldn't know resistor I would use do you?
  4. Pikey
    I have no idea. I have asked that question multiple times and no one ever wants to give up the answers. I would check out a site like vleds.com or superbrightleds.com. maybe they can help
  5. SAGO
    SAGO New Member
    Ok, will do. When I do find the correct resistor, I'll post it to this thread and we can make it a sticky. I know I'm not the first one to have this issue.
  6. SAGO
    SAGO New Member
    Ok so I emailed one of the popular and well known l.e.d. suppliers and got some really good info for everyone that has issue's with light upgrades. If its a wedge type bulb like a marker or a 3rd brake light, cargo light you have to use a 25ohm-25watt load resistor, if your upgrading a brake, light, blinker, reverse type bulb the load resistor to be used is a 6ohm-50watt. VERY IMPORTANT TO USE A LOAD-RESISTOR!!! Do NOT use a ceramic type (like from Radio Shack) they will reach temps of 200°+ and run the risk burning your truck to the ground. Its easy to determine the difference between a load-resistor and a ceramic type.... A load-resistor is made from aluminum and looks high quality and has stranded wire with shielding coming from both ends, a ceramic type is rectangular and usually white with solid wire coming out from both ends.
  7. 08_rado_rocker
    08_rado_rocker Member 2 Years 500 Posts
    awesome information! thank you for sharing this with everyone!
