Do the G80 axles have the same axel shafts as others?
Discussion in 'GM Powertrain' started by G20G80, Apr 11, 2013.
  1. G20G80
    G20G80 New Member
    Hello all
    I have 95 G20 van that I ordered from the dealer and that from the order I had a Locking Differential put in.
    In looking over the special order paperwork I got from the dealer, it lists G80 for the RPO code for the Axle.
    Had 3.42 ratio with code GU6 and with the L05 350 engine if that matters.
    At this point I now have to replace the axle shafts as they wore down pretty bad at the outer bearing and want to pick up a set but am not sure if the ones in this rear end are the same as what might have been a standard, which is what I guess is in most autoparts stores.
    For the GM axle shaft part number for what I guess is the standard as its the only 5 bolt one I could find for this year, it is: 26013313
    In looking around for just even a 1995 G20, the most similar info and what seems to be corresponding with that number is its a: 8.5 in. x 33 5/16 in. Overall Length; 5 Lugs; 30 Spline ....and if this is right, I can just get a set from the autoparts store.
    So hoping someone might know more about this then me an any help would be appreciated.
