do these dents look pop out able
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by Bowtied, Mar 2, 2013.
  1. Bowtied
    Bowtied Epic Member 5+ Years 500 Posts
    i haven't had much luck popping these out with myrubber mallet
  2. Enkeiavalanche
    Do you have a puller? You might be able to get some out a bit but not sure.. Do you have a heat gun too?
  3. Bowtied
    No heat gun but i have been considering buying one for a separate use. And the pullers, are "all equal" I saw some suction cup type ones at harbor freight in a pack that might be useful, but i didnt know if thats still what the best tool is.
    Will report back after i investigate this further.
  4. ChevyFan
    hmm, you can certainly get them most of the way out, but not sure if you will still have some impact creases or not. You can certainly try it yourself and go to a pro dent-puller if you want it done by someone who's done those before.
  5. Enkeiavalanche
    Those dent guys do a Great job at times.. Can be well worth it if you are selling a truck..
  6. ChevyFan
    I know that on trucks that I've not cared about too much in the past, I've just done the dent push-out with a mallet from behind ... and it was good enough. But, if I liked the truck and it was in overall good shape, then working a deal on a dent guy was a very small price to pay to have it basically disappear ... really pretty impressive how they work their craft.
  7. tbplus10
    Both those dents have sharp creases, so while you'll be able to get most of it out theres still going to be the crease to deal with, which means some body work.
    A crease also increases the chance that the paint will crack or chip.
  8. j cat
    the dents are too big and the metal is stretched. the use of the body hammer to shrink the metal so that the surface is shaped correctly would be required. then the metal grinding and fillers to smooth out for primer/finish coat.
  9. TimTom64b
    By taking it slow and focusing on reversing how dent was made you work them back out. The only issue is the creases... those will take some filler. My son purchased a new box for his truck with almost the same dents... and I was able to get them out all but a couple very sml creases. You'll want to get them out before the paint starts to pull from the metal.
  10. stchman
    No, they have creases. I assume you are meaning will it look like that there was no dent after the work.
    If you want that, you'll need body work.
