Doesn't like being warm.....
Discussion in 'Chevy C/K Truck Forum' started by GMANs95, Apr 11, 2014.
  1. GMANs95
    GMANs95 Member 1 Year
    Hey guys..been a while. truk is running good except for this "new" quirk. After a 20 min/mile drive,(on an already warm day) I turn truk off and when i go to restart it say 5-10 min later she no start?
    I know the IAC is new (when it was rebuilt)
    95 5.7 TBI with less than 3000 miles on reman engine.
  2. silverado002
    silverado002 Rockstar 3 Years 1000 Posts
    Assuming the engine turns over, then I would check for spark. Could be a heat sensitive ign module.
  3. RayVoy
    Or perhaps a heat sensitive fuel problem.
    Now, if there is no crank, then you probably have a starter problem.
  4. GMANs95
    Yea it turns fine. just when i drive about 20 to 25 miles on a "warm" day it gives me fits starting.
    - - - Updated - - -
    Cranks fine. starter is good. IF I let it sit for 20 min i can get it to start...may take 5 or 6 tries but it does.
  5. GMANs95
    Still having the "warm starting issue". It has now developed into acting like its missing in the morning as i am pulling out of the driveway. (Ignition module?). It goes away as i get farther down the road. On my way to work when I am stopped at an intersection..it will randomly die. Idle seems a bit low to at times but that is ECM controlled.
    I am getting ready to rebuild the TBI this weekend cuz it was the only item that wasn't rebuilt when i put the engine in...not sure why i didn't!? So I am gonna buy the gasket kit and either the ignition module or the TPS and cap and rotor. ECM may come later dunno yet.
    Ideas...advice...always welcome.
