Dome lights don't work when door opens
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by Kan1ck, Mar 4, 2012.
  1. Kan1ck
    Kan1ck Member
    2007 Silverado. Dome lights don't come on when door is opened. Dome light dash push button switch (to the right of headlight switch) is in the extended position. Dome lights will turn on manually if the push button switch (a.k.a. dash light dimmer) is twisted to extreme clockwise position, but in that mode they simply remain on even when door is closed.
    Any suggestions on what I am up against with these symptoms?
  2. thrasher
    thrasher Rockstar 100 Posts
    Does the light come on when the passenger door is opened?? If not, it may be a bad ground under the hood or at the bottom drives sied front cab to frame mount. that is where the chassi/body grounds connect. Or it could be a fuse, or the switch. I believe it is inside the door on the latch mech.
  3. Pikey
    My friend had the same issue. His door hinge pins went bad, the door sagged, it destroyed the switch in the latch mechanism.
  4. moogvo
    I am replacing mine in my '95. They extend out also but you have to wiggle them to make the lights come on. YOu can get replacements at the local Advance Auto Parts for about 10 bux.
  5. Kan1ck
    Kan1ck Member
    Well, the dome lights do not come on when the passenger door is opened.
    I will not be able to explore further until later in the week.
    I will be checking the above suggestions and if nothing is amiss, I guess my next move will be to begin checking signal circuits from the door switches to the Body Control Module.
    Thanks and will advise later.
