dont shift into second
Discussion in 'GM Powertrain' started by Burden33, Mar 29, 2012.
  1. Burden33
    hey guys the other day when i was in truck some guy in a riced out cavie try to pass me so wot in first my max rpm is set to 6500 so when the truck hit it it never switch to second gear it just cut out she keep the same speed but she will not switch to second wot unless i let off anyone know what the problem is.
  2. SurrealOne
    Ouch, Burden. I have no idea what the problem is as I'm transmissions-stupid, but I hope you get it identified. That just doesn't sound good to me, at all...
  3. tbplus10
    Which transmission do you have? 4 speed or 6 speed?
    Either way have you tried to change gears manually?
    Get a diagnostic done to see if it's throwing a code, could be a stuck servo or it could be a sensor not correctly responding to high line pressure.
    Either way It'll need a diagnostic to give you a starting point, even if you have no warnings on the dash it'll still throw a code, these new trucks throw codes for almost everything.
  4. Burden33
    Its the 4 speed transmission i had my programer read the codes but nothing came up
  5. Burden33
    well guys i figuer out the problem and it seems to be my programmer since when i return the trucck to the stock settings and tried it out it actually shifted. so u guess im going to be looking for a new programmer
