Door Handle Replacement HELP - 03 Silverado
Discussion in 'General Chevy & GM Tech Questions' started by jet89, Mar 23, 2010.
  1. jet89
    jet89 Member
    Ok so i have the inside door panel taken off and have taken off part of the clear water deflector. At this point i have access to two of the nuts that hold the door handle in place.
    However i cant find a way to access the third nut on the upper part of the handle, toward the front of the truck.
    I found the opening in the metal which would give me access to the nut, but it is being blocked by a metal bracket, or guide, or something, that seems to be holding the window in place. From a side view i can see that it is 'U" shaped which the window is sitting in. And like i said, it is right in front of where this nut is. So i cant get to it.
    Any suggestions/ideas?
    Here is a link that has step by step on removing Door Handles,
  3. hildy19
    hildy19 Rockstar 100 Posts
    This shouls help me too thanks
