door handle replacement
Discussion in 'How-to Guides' started by Silverado Junkie, Jun 10, 2010.
  1. Silverado Junkie
    Silverado Junkie Rockstar 4 Years 500 Posts
    Wel my inner door handle broke on my '95 Silverado and so I had to replace it. When you go to buy a new door handle, you have to buy the whole assembly with the electric lock unless you go to a salvage yard, but luckily AutoZone sells em for $25. All you have to do to replace the handle is remove the two phillips screws from the hand hold you use to shut the door, then romove the outside face around the door handle. Then pull the door panel off. Be sure to unhook your buttons on the door from their electrical plug ins to get the panel off. Then drill out the rivet holding on the door handle assembly on and unhook the rod on the back of the door handle. Install your new handle assembly and rivet it back in. The assemble the way you dissasembled it.
    1 person likes this.
