Door Lock problem
Discussion in 'GM Electrical Tech' started by TELORVEHC, Oct 26, 2010.
    Ok so, I have a problem with my door locks, whenever I hit the lock/unlock button on the power lock switch, only the driver side door locks. The passenger side lock moves also, but does not lock/ unlock like the driver side door. The door lock has to be manually pushed forward 1/4 in. or so so the door unlocks fully. Any ideas on what the issue could be? I was thinking maybe a door lock actuator or something :neutral:
  2. Springthing
    Sounds like you have door lock actuator going out. Is the door lock difficult to move manually? If so you could have an issue with the door lock itself sticking...but most likely door lock actuator. Not all too expensive if you look around, I don't think, and not all TOO difficult to swap out, provided your fingers and hands are double jointed. :)
