Door Window Switch Illumination (Won't light up)
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by vdubn, Nov 2, 2009.
  1. vdubn
    vdubn New Member
    I have been searching the forums lately trying to see if anyone else has this issue, or might know what could be causing it.
    Basically, none of the switches on the doors will light up, not on any door.
    I have checked all of the fuses on the drivers side of the dash, and under the hood, and they are all fine, none are missing, etc.
    I pulled the drivers side switch panel out of the door, and it all looks fine. All switches work perfectly, they just wont light up when the headlight switch is turned on.
    Have any of you had this issue, or found what was the cause?
    I am beginning to think it might be the headlight switch, but not sure how to test before just replacing parts.
    Any help would be greatly appreciated.
    Almost forgot, its a 99 Suburban 1500
