doors sag? and air leak
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by nabisco_12, Jul 9, 2012.
  1. nabisco_12
    nabisco_12 Member
    Ok i have a wind air leak on my driver door, blowing the right way it is as loud if you have the window open... i found that my hinges need work, so i called the dealership figure they could do it and they said over 600!!!!! so i called the gmc dealer and he wont do it he said i had to go to a body shop and they have to take out the dash and drill and put bolts in...800$ wtf?? they said that the autozone ones will last 3 months....
  2. kw70chevy
    kw70chevy Member
    change your door hinge pins before you take it to the dealer. you can get them at the auto parts store.the bushing wear out and cause the door to sag.
  3. tbplus10
    I second the door hinge pins and bushings, it'll be a lot less than $600.
    Dont let them fool you with that line about only lasting 3 months either they dont use any special metal that aftermarket parts arent made of.
  4. Coach24
    Most door hinge parts come from the same manufacturer as the Dealer gets them from through Gm, at a greater expense and markup. Dorman is a very good brand to look for.
  5. dipstick
    If you change the bushing /pins ..make sure to get the tool to compress springs pita.
  6. tbplus10
    Good point, it can shorten the work time considerably having the right tools and they arent that expensive.
  7. nabisco_12
    nabisco_12 Member
    so what exactly is this compression tool called? and i take it Dorman is the brand to use?
  8. nabisco_12
    nabisco_12 Member
    i dont see where i would need to compress a spring at?
