Driver's side turn signal not working.
Discussion in 'Member Introductions' started by jeffc, Apr 24, 2009.
  1. jeffc
    jeffc New Member
    Hi,
    I am new here because this is the first time my truck (2005 Silverado 1500) has failed me. I searched the forum but didn't find my specific problem. The left turn signal has stopped working via the turn signal lever or the hazzard switch. I have swapped fuses and bulbs from left to right (only turn signal bulbs) and the left side still fails. Am I looking at the steering column lever or hazzard switch problem or something else? I am off to buy a repair manual.
    Thanks in advance for any help.
    Jeff
    1 person likes this.
  2. Ronny
    Ronny Rockstar
    Have you checked the wiring and ground?
  3. retired2001
    Welcome to the site! Like Ronny said, I'd make sure the "ground" is good to start with. Good luck!
  4. bry2500
    If your grounds are fine it could be the flasher or the relay.
  5. Dr_Zero
    Check this out it might help some
    http://www.gmtruckclub.com/forum/showthread.php?p=126254&posted=1#post126254
  6. 99'HEARTBEAT
    Welcome to the site,from Calif.
