DRL problem
Discussion in 'General Chevy & GM Tech Questions' started by logic09, Oct 19, 2009.
  1. logic09
    logic09 New Member
    So ive come to notice that my drl dont work any more at all an i know that its suppose to be the high beams at like 75 percent i remember at one time i put higher wattage bulb for my low beams an wondering if that could of messed it up or is there a fuse somewhere that i could replace thanks i appreciate it
  2. TRPLXL2
    What year make and model are you driving, that would help this problem out a little. I had an 05' Silverado that my DRL stopped working, and it did have a fuse that was blown which once it was replaced fixed the problem.
  3. TRPLXL2
    Okay I just saw your introduction post, 1996 Tahoe I am not sure if that would be the same as mine or not? That is probably the problem though, especially if you used a higher wattage bulb in the low beam. I had put some LED's in my turn signals, and it blew the DRL fuse even though the LED's drew less power.
  4. logic09
    logic09 New Member
    So then most likely it will be one of the fuses then inside the car
