Discussion in 'Chevy C/K Truck Forum' started by DOGMANN, Feb 26, 2011.
    DOGMANN New Member
    Im looking at a 99 C3500 Dually with a 454. Tis will be my 1st Dually and I wanted to know about the rear tires.... How do you check the air on the inside back tire? If you get a flat , how do you change it?
  2. mad1500hd
    mad1500hd Rockstar 100 Posts
    Hey Dogmann...the rear inside tires have a nipple that sometimes have it so you can reach it from the front tire...you can buy extenders that you can put on that will allow easier access from the front...changing the inside rear tire is like changing any other tire, but you have to do it twice...take the outside tire off...then take the inside tire off...put your outside tire on the inside and then put your spare...it really is a bitch :tongue:, but it can be done...hope this helps...
    Oh...and good luck!
  3. silveradotrailblazer
    X2 what mad1500hd said. They can be a bitch, but how often do you plan on getting a flat? If you need a dually don't let this stop you.
    what both sayd + if you need a dually don't buy a 454 !!!! it will eat you alive ( GAS ) !!!!
