DVD display while driving
Discussion in 'Audio, Video & Gadget Tech' started by blcdog, Oct 2, 2009.
  1. blcdog
    blcdog New Member
    Anyone know how to bypass the lockout to display the dvd in the Nav screen while driving?
  2. project86
    project86 Member
    try setting your park brake to the first click that should bypass the lockout and it won't hurt your park brake.
  3. Land Shark
    Land Shark Rockstar 100 Posts
    If it's an aftermarket install they usually hook it up to the sensor that tells the vehicle is in park. You may have to ask someone at a local audio shop.
  4. vncj96
    i wouldnt mess with the parking brake, depending on the year of vehicle and what it is, it can be very touch on setting the parking brake. If its a factroy DVD it could be pretty tough to take that safety feature out. Most likely it is embedded within the computer. As most stuff in the stereos are these days. If its aftermarket it is hooked to the parking brake or the transmission and it can be switched over.
  5. darksight
    darksight New Member
    I dont suggest that you override the safety feature of your head unit. Its that way so you will pay attention to your driving an not the dvd thats playing. Here is a link:
    :slap: just be smart when using this unit.
  6. LDB
    LDB New Member
    Having a DVD playing visible to the driver is an invitation to disaster. I'd like to think nobody would be stupid/foolish enough to do such a thing and that having a vehicle capable of such a thing would incur an appropriate fine to make it too risky to do it.
  7. Mean_Green_95
    Hook it up to a toggle switch, I did this to a friend's truck so her nieces and nephews wouldn't be so bothersome while driving.. This is so that when you are driving you can quickly switch it off in an emergency, like is a copper is lurking around. But I suggest not to even play it while driving.
  8. sfilipe
    sfilipe Member
    Depends on the make of your headunit. Some of them you can just ground the wires that connect to the parking break. Others are harder to bypass. I know on my alpine iva w505 it needs a whole break sequence of: foot break, parking break, release parking break, parking break again, release break. So there is a module to bypass this called the tr7. There are two different makers of this so search around. This works for Alpine and probably other headunits but find out before you order.
  9. Custom04Chevy
    Custom04Chevy Rockstar 100 Posts
    I couldn't agree more. It's illegal for a reason.
  10. Michaelofhearts
    Michaelofhearts New Member
    Well Ill answer your question....Ground the wire. It will work as if the parking break is down.
    (on most models) some have more advanced sensors, but this has worked on every head unit I've installed
