e load rated towing tires
Discussion in 'Wheels & Tires' started by pewterburb, Mar 22, 2010.
  1. pewterburb
    pewterburb New Member
    finally got the travel trailer, 32-ft regular hitch, to tow behind the 99 suburban, 5.7-liter vortec 350, as long as it can. ran across discussions about putting e load rated tires on the pulling vehicle to give stiffer sidewalls to help prevent sway (got the bars, too) and possibly even to help a bit with gas mileage.
    only trouble is trying to find decent tires sized (235/75/15) or something that will go on those stock custom 15-inch rims on the burb. could go with d rated tires but i'm leaning toward the e's. michelin has an a/s tire but it starts at 16 inches.
    any knowledge of a tire out there that would be an e series with a decent reputation that would be in a 235/75/15? if so, i haven't found it. did run across the kumho tire and no i wouldn't put that on anything :lol:
  2. pewterburb
  3. pewterburb
  4. pewterburb
  5. moosetags
    moosetags Rockstar 100 Posts
    Greetings from the Florida Panhandle
    I pull a 7400# Airstream travel trailer with a 2004 2500 Suburban. I use laod range E Michelins from Sams Club. Load range E's do start at 16 in. @500 Subs come with 245x75R16 E's. I replaced my original with 265's.
    With that big a trailer make sure that you use a quality weight distribution/sway control hitch system. Also check the hitch receiver on your Sub. The OEM receivers on GM trucks are junk when it come to heavy trailers. I have had weld cracks on two of them.
