E3 Spark Plugs
Discussion in 'Performance & Fuel' started by Clint16, Apr 12, 2012.
  1. Clint16
    Clint16 Member
    Well its about time for new spark plugs in the chev, are the E3 spark plugs all what there cracked up to be? worth it? anyone have expierence with them?, they claim to be awesome. Thanks!
  2. moogvo
    It's all marketing hype. Your truck was made with AC Delco, you should go back with AC Delco... Not Bosch, not E3... Delco plugs were made for your truck.
  3. Asphalt Animal
    Asphalt Animal Rockstar 100 Posts
    AC's have always worked best for me too. I tried Bosch plugs years ago and pulled them out hours later and tossed them! Wasn't even worth my time to return them.
    If they have the Rapid Fire plugs available for your year, get those!
    *they were a modified design plug w/ a tapers electrode and ground strap. Made my old Pontiac run smoother, more responsive too. Depending on what plugs came in your truck, and whether they still make them -- if they do, but them!*
  4. Clint16
    Clint16 Member
    Thanks for the info guys! I thought it was a little too much to be all true .im glad i know what to get now. Cheers!
  5. moogvo
    Glad to help save you a few bucks and probably some frustration!
  6. Goldie
    Goldie Epic Member 5+ Years 1000 Posts
    I ran a set of E3's in my 07 4.3L and they performed as advertised. However, after 20,000+ miles they started to cause the engine to misfire. I went back to OEM plugs and haven't had a problem. I can't recommend the E3's.
  7. osgprometheus
    osgprometheus Rockstar 100 Posts
    Here is my theory. Just a theory..
    E3, Split Fire, Quadra Fire, ect...
    They are all the same. Look at electricity. It takes the path of least resistance. Hence... They may work great in the beginning, but after they start to wear, they will take the most worn easiest path. Fire to 1 spot. Not multiple. Causing a weak fire, or missfire.
    IMO
  8. 06MonteSS
    06MonteSS Rockstar 100 Posts
    no good.. stick with stock or NGK's... these things are garbage... have seen sooooo many people have problems after installing these plugs - and once they switched back, problems solved...
  9. cedicol
    cedicol Member
    AC Delco platinum is the only spark plug i want in my truck. Her in Belgium we drive on LPG en therfor you need the platinum.
  10. Clint16
    Clint16 Member
    wow it sure is amazing how a product can be so troublesome and garbage after their so called "amazing", thanks a lot for the info!
