EFI Live Flash Scan vs. Hypertech Hyperpac
Discussion in 'Programmers & Tuning' started by csm, Jun 3, 2011.
  1. csm
    csm New Member
    I'm looking for a device that will allow me to capture performace data on my truck before and after modifications. I'm especially interested in tracking horsepower, fuel economy, 0-60 times, etc. Most of the devices on the market are strictly designed to perform tuning functions - I haven't found many that simply record performance results.
    So far, I've come across the EFI Live Flash Scan V2 and the Hypertech Hyperpac. Has anyone had experience with these devices - perhaps both to provide a comparison? Pros/cons for each? Are there other devices that perform these functions?
  2. ZSI52
    EFI Live or HP tuners. Most tuning shops use either of those brands. I believe EFI Live has some forums on their website that you could probably check out.
  3. darnie1987
    darnie1987 Rockstar 100 Posts
    my 2 cents, hyper tech is like you said, a programer.... it has its limitations. a "tuner" such as efi live or hp tuners is a tuning device. it also helps if you have a wide band set up to go along with it but as far as the difference in performance, and options id go with efi live or hp tuners any day. i have a pcm done with efi live and it beats a heck out of the superchips tuner hands down and a retune is like 15 bucks cant beat it...
  4. chucksrt
    chucksrt New Member
    Efi live is $1000 You can get a reflash done by PCMfroless.com for around $500. However you don't get the programmer like you do w/efi live. You should have the car dyno'd before and after as well w/ A/F readings.
  5. csm
    csm New Member
    Is it true that EFI Live is not compatible with Ford's?
  6. darnie1987
    ya but like all things you get what you pay for? heck i prob wont buy it but ill easily spend the money with m y tune, i have a nelsons tune and with that and the gauges and wide band it will rack up some funds, but i wont have a code reader or anything like that. if your wanting to go fast get efi live, if u want to just be quick get a mail order tune there usally pretty spot on. and then id rank a hand held... just my 2 cents... :)
