Electrical problems
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by Jim b, Oct 6, 2013.
  1. Jim b
    Jim b New Member
    I have a 2001 extended cab silverado and about 2 weeks ago the radio stopped turning off when I turn the truck off and open the door, and now the only way my power windows work is if both doors are open. I checked the wires going from the body to the door and they are fine. Any help would be great.
  2. j cat
    my guess is the RAP relay
  3. Jim b
    Jim b New Member
    Do you know where the rap is located?
  4. j cat
    should be in the fuse box.
    - - - Updated - - -
    this relay is controlled by the BCM ...the coil return ground side is what the BCM grounds out to energize this relays control of the interior lights/radio/windows... so you have to see what is the cause of this .wiring, relay, bcm or something else. with diagram and a voltmeter it should not be too hard.
  5. Jim b
    Jim b New Member
    Ok. I'll check it out. Thanks for the help.
