Engine misses while driving and poor gas mileage
Discussion in 'Chevy C/K Truck Forum' started by Arbitert343GS, Jun 1, 2013.
  1. Arbitert343GS
    Arbitert343GS New Member
    I have a 1999 Chevy C1500 with a 5.7 and while driving my engine misses(tach bounces around), but at idle its ok. Also Im getting like 7 MPG and I have no check engine light on. What might be the cause of this?
  2. JimmyA
    JimmyA Rockstar 4 Years 100 Posts
    Spark plugs and wires would be my 1st check!
  3. Arbitert343GS
    Sorry, I forgot to say, I also just put new spark plugs, wires, cap, rotor, fuel pump, and fuel filter on it.
  4. baumann6
    baumann6 New Member
    I think I am having the same trouble as you the only thing that sounds different is when I first start it it sounds like it is missing also. I have tried a cap and rotor also as well as a fuel filter and ran some fuel out in a bottle to check for water in fuel but it looked clean. I am maybe thinking a fuel pump but don't want to change it and that not be the problem.
  5. 4x4squared
    4x4squared Rockstar 100 Posts
    just toss a fuel press. tester on it and see if youre running in an acceptable range. another quick check you could do is grab a can of ether and while its idling, spray down your vacuum lines one at a time and see if your idle changes.
    remember, ethers not the best for your engine lol if you find a leak dont keep sprayin :p
    and check that air filter lol doubt its makin you miss but its overlooked a lot and for $10 its worth changing. if your truck cant breathe its gonna drop fuel mileage.
  6. baumann6
    baumann6 New Member
    What is the proper fuel pressure for these trucks.
  7. 4x4squared
    i wanna say about 10-13 psi for a tbi 350... not 100% sure though
  8. Pikey
    I would also consider checking your egr valve.
  9. Sirwriter
    Sirwriter New Member
    For 1988 to 1995 the pressure is 9 to 13; from 1996 and up it is 60 to 66 psi. This is for V-6's and small block 8's.
    Sirwriter
  10. Crockpot
    Crockpot New Member
    I would check your carburetor, vac lines, and oil. My truck was having difficulty and I rebuilt the carburetor and it started to work much better.
