Engine not starting
Discussion in 'Chevy C/K Truck Forum' started by Arbitert343GS, Apr 29, 2013.
  1. Arbitert343GS
    Arbitert343GS New Member
    I have a 1999 Chevy C1500 with a 5.7 and I recently swapped frames(the only thing done to the engine was it being pulled, I did no other work on it), well I hook everything back up(used wiring diagrams to double check) and now its giving off an intermittent spark from the coil. And will not start at all. Any ideas?
  2. tbplus10
    Either a bad coil, bad positive connection, or bad ground.
    Double check your connections, I suspect the coils good but you either have a loose ground or you might have internally damaged a wire during assembly.
  3. Arbitert343GS
    Thank you for the help! It ended up being condensation in my distributor. I got it running earlier after I let it dry out.
