    Join Today ~ It's Free
Engine swap on a 2001 silverado
Discussion in 'General Chevy & GM Tech Questions' started by 01 casper, Jun 30, 2010.
  1. 01 casper
    01 casper New Member
    I am wanting to do a engine swap from a 4.8 to a 6.0 will I have any problems?
  2. Silverado Junkie
    Silverado Junkie New Member
    Besides a problem with cost because a new motor and computer costs alot, a 6.0 wont bolt up to a 4l60e tranny as far as I know. They do bolt right up to a 4l80e tho.
  3. 01 casper
    wow I need to look into which tranny I have. Thanks
  4. Mean_Green_95
    Mean_Green_95 New Member 1000 Posts
    The 4l60e will bolt up not problem. You will need the flywheel off the 6.0. I don't believe the 5.3's flywheel will bolt up to the 6.0. Other than the obvious things like the 6.0's wiring harness, intake, exhaust, you will have to get a tune for the engine and trans to work properly together without any trouble codes.
  5. 01 casper
    will the wiring harness from the 4.8 work on the 6.0 as in the injectors mas and so on? And yea I know about having the computer flashed so it will work with the 6.0 I already have someone lined up for that.
  6. Mean_Green_95
    I don't know if the harnesses with interchange. I don't believe they will, but don't hold me to it. You best bet is to call a good custom shop and ask them. But the easiest thing to do is to make sure the motor you buy comes with the harness.
  7. 01 casper
    ok thanks for the info.
