Error code P0122
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by COSSilverado, Jul 10, 2009.
  1. COSSilverado
    COSSilverado New Member
    Hello, I am new to this forum and have a question. I have a 2000 Silverado 4x4 with the 5.3 engine w and automatic and just threw a P0122 TPS/Pedal position Sensor A circuit low input code last night.
    Has anyone else had this problem and if so any guidance on troublshooting the problem or what the fix action was? Any assistance would be greatly appreciated.
    A newbie...
  2. Jimmiee
    The last time I saw that code the APPS sensor was bad. Has any electrical work been done on your truck recently? Did you get any water inside the cab?
  3. eallanboggs
    eallanboggs New Member
    Got to love Drive-by-Wire. Next comes steer by wire and brake by wire. Isn't technology grand?
  4. bill190
    bill190 Rockstar 100 Posts
    In the throttle body is the throttle and connected to this is a sensor. This sensor tells the engine computer how far open the throttle is. As the throttle opens, the computer knows to add more gas because of this sensor.
    The diagnostic code you are getting is saying that the voltage the computer is reading from this sensor is lower than it should be getting.
    First check that the battery is 12 something volts with the ignition on and not started (with a voltmeter). Then should be 13/14 volts after starting and the alternator begins charging the battery.
    Then the problem with this sensor could be a loose electrical connector, or the sensor may just be worn and need replacement.
