Excessive Oil Consumption
Discussion in 'General Chevy & GM Tech Questions' started by dbrannen, May 30, 2010.
  1. dbrannen
    dbrannen New Member
    I have a 2006 Silverado 1500 with 60k miles and use 1-2 quarts of oil every 3000 miles. I seem to have some dirty oil residue on my valve covers... No drips or smoke. Is this common? Should I have it checked? Thanks
  2. murdog94
    Well take a look at the rear main seal (between where the block and tranny mount incase you didnt know) and also what oil are you running?
  3. dbrannen
    dbrannen New Member
    Ok thanks. I will check it out when I get a chance.
  4. bigdaddy77084
    bigdaddy77084 Epic Member 5+ Years 500 Posts
    What brand oil ya running?? 60k the motor will be dirty. If its not leaking its going out the tailpipe..(rings or leaking valve guides).
    2 quarts leaking you should see it somewhere, is the bottom of the
    truck wet with oil?...good luck
  5. silveradotrailblazer
    I'd have it checked out, thats way to much oil every 3,000 miles.
  6. Silverado Junkie
    Silverado Junkie Rockstar 4 Years 500 Posts
    If its still under warranty, id take it in to the dealership.
  7. Jimbo3
    Jimbo3 Rockstar 100 Posts
    I am having the same problem... GM says normal is 1 QT every 2 thousand miles... I'm burning 1.5 QT in 3 thousand miles
  8. dsfloyd
    Id be worried if GM says that. If thats the case then they are making some crap motor innards. My 04 with 80k doesnt burn any oil (and I am knocking on every piece of wood I can find right now since I just wrote that:whip:).
  9. swrevin36
    swrevin36 New Member
    My 05 Avy had 141000 and never used more than .5 quarts even on 5000 between oil changes.
  10. 03 SIERRA
    03 SIERRA Rockstar 100 Posts
    same issue i got. ive trid thicker weights, ive tried thinner weights, and additives. What about the oil life system, do ya build up sludge, too much maybe, cause parts to leak?
