Exhaust help
Discussion in 'General Chevy & GM Tech Questions' started by 1BadSierra2011, Jan 3, 2013.
  1. 1BadSierra2011
    1BadSierra2011 Member 1 Year
    Well I have taken off everything on the 2011 sierra, from the cats back. I had it straight piped and loved the sound it was awesome. But it seemed to gain some sort of a knocking noise, so I put a flowmaster back on. My question is how can I straight pipe it(cats back) without causing any damages. Or does it cause any damages at all? Thanks guys!!
    Cody
  2. mfleetwood
    I moved your thread here as it should generate more responses/opinions.
    Someone should be along soon who could provide you some insight.
  3. Conlan Rose
    You may actually lose HP because you have removed to much back pressure.
  4. 1BadSierra2011
    I was told it could mess up my motor but i dont really know much about gas engines.
    - - - Updated - - -
    I plan to have it true dual straight pipe from the cats back, dont know if this will hurt it or not, anything i could add to gain more back pressure yet still have the same exhaust sound?
  5. 1BadSierra2011
    Any help? lol
  6. ahmitchell1
    If your running pipes all the way to the back you should be fine running straight pipes just don't run anything over 2.75
  7. 1BadSierra2011
    Will the dealer still cover damages if its straight piped? as long as it is cats back should be fine right?
  8. mudpuppy
    mudpuppy Rockstar 100 Posts
    the dealer will seek out any and all reason to void responsibility. as for the knocking noise, thats detention due to low restriction allowing for a fuel build up causing a continued burn down the pipe. this will/can effect the engine. straight pipes are nice and can be done easily by crimping the pipe around the same location that the cats would be to maintain a proper back pressure. make sure to crimp past the o2 sensors, not in front of them.
  9. 1BadSierra2011
    Is there any muffler I could put on that sounds like straight pipe? I love the popping and loudness
  10. Boonduff
    The Cherry Bomb Glasspacks sound pretty close to straight pipes. Try and find the shortest ones you get.
