First problem with HIDs
Discussion in 'Lighting Discussion' started by redneckarmyMP, Feb 10, 2010.
  1. redneckarmyMP
    redneckarmyMP Epic Member 5+ Years 500 Posts
    Well after having HIDs for almost 2 years I've run into my first major problem.recently I've noticed the passenger side light is much dimmer than it used to be.does anybody know what the problem could be?ballast?bulb?
  2. Mean_Green_95
    call up any car audio shop. A lot of them handle HIDs and might be able to answer you.
  3. oohyeah4
    oohyeah4 Member
    sounds like a bad ground.
  4. dsfloyd
    easiest thing would be to switch ballasts. if the problem switches sides it is the ballast. if it stays the same probably the bulb. ddm tuning has great prices. just bought a few sets of HIDs. bulbs are 15 for a pair. I think ballasts were a like 25 but you can get new ballasts and lights for 30 or 40 depending on if you get 35 or 55w ballasts. the lights will all be rated to 60w. Since you have had them for 2 years I wouldnt suspect needing a relay or anything.
  5. redneckarmyMP
    i never could figure it out so i ended up just ordering new ones.they came in on friday, installed them and theyre working great!
