Discussion in 'General Chevy & GM Tech Questions' started by Santoy956, May 31, 2011.
  1. Santoy956
    Santoy956 Member
    Ok. so i got up in the morning to go to work and when i started my truck it sounded like the flywheel was loose. but i was wondering if you would be able to hear it while you were driving? Havent had time to check it so any help is appreciated. thanks. :neutral::neutral::neutral::neutral:
  2. What makes you think the flywheel is loose? some kind of noise, if so try to describe it. Normally if the flywheel is loose or cracked it will rattle in neutral but as soon as you put a load against it it will stop. If you are hearig a noise while driving it is unlikely a flywheel problem unless you ran over something and bent something and the flywheel is rubbing against it.
