fog lamps
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by PolishSilverado, Jan 6, 2013.
  1. PolishSilverado
    PolishSilverado New Member
    hey i have a 2000 silverado and dont have fog lamps i have connectors where fog lamps should go and i have a fuse in the fuse box but no relay and dont have a switch for them on the dash i dont want to buy the lights to find out it doesnt work what should i do?
  2. Kady
    Its always possible to add it, just depends how much work you want to do.
  3. Enkeiavalanche
    Kady nice new pic... Yes you can add them and it's not too hard.. You can also get a factory switch..
    1 person likes this.
  4. rmck490
    rmck490 New Member
    I installed the fog lights to my 2000 MY. It didn't come with them. This required a new light switch to include the fog light button, installing a relay, installing a wire harness, and my local dealer to reprogram the BCM to recognize the RPO code (T96).
  5. PolishSilverado
    ill see i want them but don't want to go through all the hassle of putting the wire harness and going to the dealer
  6. shibby2oo8
    shibby2oo8 Member 2 Years 100 Posts
    It looks like you have aftermarkets already so why not get oem's and wire them like those you have? I would do that because i hate that i have to turn them back on after i cycle the key. Bunch of ways to do it, i would have a 3 position switch and have it wired to the headlight switch and to battery so it would come on whenever the headlights do or anytime you hit the switch.
  7. KidHauler
    I replaced the factory fogs in my wife's 02 with aftermarket direct replacements. They, too, had lens seperation and have since failed. After a discussion with another member here, she pointed me towards the Hella F55, or 550, which fits in the factory opening, and is a much better light.
    You could take some measurements for the opening, and just match up a better fog light that fits. Wire them to their own switch, or the parking light circuit, and you'll be set.
    Good luck, and welcome aboard.
  8. Pikey
    I would not waste the money on oem fog lights. I had one the was broken, bought a new one thru GM and the light sucks. The beam is terrible, you can hardly tell that they are on. The cheap ones one ebay and amazon are even worse when it comes to the beam pattern and light scatter. I would go with the hella 550's. That is my next upgrade.
  9. shibby2oo8
    I have had luck with ebay oem housings. The two I replaced were the factory originals that either fell apart or got hit by a rock or something. I like keeping them on because I have 6k xenons and the oem fog lights on tell people that they are my low beams not the highs. But most people dont know that the fogs turn off when the highbeams are switched on so they still flash their brights at me and I flash all 4 of my 6k xenons right back...
  10. Pikey
    I bought one of the ebay oem housings for the passenger side on my 03. The ebay housing threw a terrible pattern compared to the remaining driverside factory housing that was on my truck. The light was scattered everywhere. Maybe I just got a bad one.
