Fog light install
Discussion in 'Chevy Truck Accessories' started by BlueEagle, May 9, 2010.
  1. BlueEagle
    BlueEagle Member
    I picked up a set of aftermarket fogs but the wires ae to short to run into the cab. So I got the idea of splicing them into my low beam wires is this possiable to do or will the added need for power blow a fus or something else?
  2. at4rxj
    at4rxj New Member
    Yes, wire in a relay with power from battery to relay then to fog lights, and tap into your headlight wire and run that hot into your relay for the switch.
    You sure you want them to come on every time your lights are on?
  3. BlueEagle
    BlueEagle Member
    ok. So if I do it with the relay, Ill be fine then right?
    Not sure about the fogs being on all the time< so thinking about that. Might jst get some more wire. I was just covering some avenues of where I could go with it.
