frame bracket modification?
Discussion in 'Lifted & Offroad Suspension' started by GunRock0811, Mar 30, 2010.
  1. GunRock0811
    GunRock0811 Rockstar
    I'm pretty close to buying the rough country 4 inch lift. On the notes though it says frame bracket modifiication required. I've never put a suspension lift on before, what does this mean? I searched for it but no luck. Thanks
    05 silverado 4x4 ext cab (3inch body lift) :slap:
  2. sharpshooterusmc
    sharpshooterusmc Rockstar 100 Posts
    u have to cut a piece off the drivers side where the lower control arm was originally bolted on, it has no effect on the frame of the vehicle, iv put on quite a few of these lifts
  3. GunRock0811
    Thanks bro, just wanted to make sure it wasn't anything major
  4. adampaul1964
    You have to cut the rear differential mount from the frame and cut the mount off the differential itself and grind the cooling fins to gain clearance. Look at the instructions on the link you posted for more info.
  5. GunRock0811
    I did breeze through them pretty fast...see what you mean now. Feeling kind of like a moron...:fighting0072:
