Front Bow Tie?
Discussion in 'Chevy Truck Accessories' started by Silverado1500, Jan 17, 2010.
  1. Silverado1500
    Silverado1500 Rockstar 100 Posts
    i wanted to paint my bowtie black and i had some black duplicolor for painting wheels left over. would this be good paint to use?
    and should i prime also?
    so sand, then prime, then sand again?, then paint?
    do i have to sand between every coat?
    i also have duplicolor clear coat, should i use that also?
  2. s5belford
    s5belford Epic Member 5+ Years 1000 Posts
    don't sand between coats
  3. Stealth
    i would just lay it on according to the instructions on the can. it seems pretty simple once you read them. just make sure you give it plenty of time to cure
  4. cliff334
    cliff334 Member
    id recommend using using plastic paint and primer it has a little more flexibilty with out cracking...scuff, prime, wet sand, base coat, clear
