Front Diff problem
Discussion in 'GM Powertrain' started by jnbascom, Dec 14, 2009.
  1. jnbascom
    jnbascom New Member
    Okay folks, there a lot of threads on this issue but I am getting more confused by the minute. I have a 1999 GMC Jimmy with the push button 4X4 (4 button). When I press the buttons everything works correctly except the front diff wont engage. The transfer case is working properly and the drive shaft is turning. There is a cable running to the diff then under the batt tray. The cable moves freely but there is no vacuum going to the diaphram. Tracing the lines back there is a switch on the fire wall but no vacuum to it either. Where do I go from here?
    Don't know if this helps but my selector switch for the heater/AC controls won't work either. just blows out all the vents. I have been reading about a vacuum line on the back of the motor near the distributer that controls both the 4X4 and the heat/AC controls. Could this be the problem? I have a vacuum line that goes no where and wondering if this "T" near the dist is where it should go.
  2. brianj
    brianj Rockstar
    I would say you are losing vacuum somewhere, and it sounds like you have found the spot.That would explain both problems.
  3. jnbascom
    jnbascom New Member
    Hooked up the vacuum line. 4X4 worked good for 2 tries and now it is stuck in 4X4 auto. I disconnected the vacuum line and it still is stuck in auto on the dash but the diff disconnected itself. What happened to cause this?
