Front end noise 1999 K1500 'Burb
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by Georgia_Dave, Oct 7, 2013.
  1. Georgia_Dave
    Georgia_Dave New Member
    I have already searched the forums looking for answers, but I figured it couldn't hurt to give some specifics and see what kind of responses I could get. My truck has 213K miles on it, is in overall pretty good shape, but it is 15 model years old with all those miles. This front end noise happens mostly at low speed when I first take off. It sounds like flexion really. It's a kind of groaning and a light "thunk" when I accelerate from a dead stop. Also, if I kind of lurch it in first gear, it does it when the front end lifts up and when it goes back down. Sometimes I hear it when I come to a complete stop as well. I experimented today and tried holding the brake down and easing the accelerator on and I didn't hear it. I was kind of trying to rule out drivetrain stuff I guess. At any rate, when holding the brake down and applying accelerator the noise isn't there, only when the body moves from accel/decal. The location of the noise seems to be from the front driver's side. Any input would be helpful, feel free to ask anything additional that you need to know.
  2. dsfloyd
    First thing I can think of (especially with the mileage) is to go through and inspect the suspension and steeing linkage (idler, pitman, ball joints, tie rods etc.). Those will typically give wandering feelings, clunks or tire wear but sometimes things make different noises.
    Easiest way to do this is to put a jack under one of the lower a-arms and lift the tire about and inch or so off the ground. Grab the tire at 3 and 9 and push/pull the tire back and forth. There should be very minimal movement. If there is movement or clunking have someone look at the linkage while doing this to locate worn part (idler, pitman, and tie rods). Next grab the tire at 6 and 12 and do the same thing, if there is movement it is typically at the ball joints. One other ball joint check is with the same setup take a long prybar and place the end under tire and go up and down on the handle looking for movement at the ball joints. Bad hub bearings may also have movement on the side to side and up down movements. Repeat on other side of truck.
  3. Pikey
    does it make the noise when you bounce up and down on the front bumper?
  4. Georgia_Dave
    Pikey, yes. When I vigorously press up and down on the front bumper it does make the sound. I should probably also say that otherwise this truck does fine. I've recently driven it on several moderately long road trips (200-300 miles each) at interstate speeds and it drives fine. The clunk/thunk is only noticeable when I first apply the accelerator from a dead start.
  5. Pikey
    I would check your lower bushings on your front shocks. Then your swaybar end links. You can lay under the truck and have someone bounce it up and down while you search for the noise. That is how I found my bad front shock bushings.
  6. lucid
    lucid New Member
    I'm new here but that sounds similar to what was going on with my last 99. Mostly at low speeds is the key. There was a problem with the front hubs on some of these and the wheel speed sensor would malfunction (only at very low speeds) and cause the anti lock to engage. For me, when I changed out the hub it went away.
