front end question
Discussion in 'Lifted & Offroad Suspension' started by Cuda1500, Jul 24, 2010.
  1. Cuda1500
    Cuda1500 Member
    are wider offset rims harder on front ends, im running 15in by 10in wide rims with about 4.5 backspace i think cause they stick out about 3-4 in past the fenders on my 97 gmc 1/2 ton 4wd , and does a wider and more offset rim make the tires rub worse cause im running 33x12.50r15 on my truck with a 3 in body lift and they rub pretty bad in reverse.
  2. silveradotrailblazer
    I have 16X10 with 4.5 offset on my '96 Suburban with a 6" lift and 35's. Had to trim the front bumper a little. I haven't had any unusal front end wear. I have over 200,000 miles on the Burb. I rebuild the front end (balljoints, tie rod etc etc) every 100,000 miles and the parts have normal wear and tear. I do grease the front end between 3,000 and 5,000 miles.
