front hub
Discussion in 'Lifted & Offroad Suspension' started by alw, Oct 2, 2010.
  1. alw
    alw New Member
    How hard is it to change the front wheel hub on 2006 lt silverado 4wd. I have a new hub but I don't know if I should tackle it. I have tons of tools being a plumber?
  2. murdog94
    Its fairly simple you just have to disassemble the brakes, and i use an air chisel or regular chisel to pull the old hub bearing ou. But your best bet is to buy something like a haynes manual to change it so you have something that is step by step to refer to. and as i said it really isnt to bad of a job and you will save yourself $100 in labor! Oh and if its a 4X4 then you need a 36MM socket to remove the CV Axle.
  3. alw
    alw New Member
    Thank going to attempt tommorow!
