Front sway bar?
Discussion in 'Lifted & Offroad Suspension' started by ct9a, Aug 12, 2008.
  1. ct9a
    I was under my '94 Suburban the other day when I noticed something that made me really curious. The ends of my front sway bar aren't connected to anything! There's holes in them as if to mount somewhere, but I can't seen anywhere where they could even reach to be able to mount. It's like this on both sides. Is this normal or am I missing some links or something? Maybe an off road mod or damage from the previous owner?
  2. MWright936
    Sounds like you're missing an end-link! Maybe two, if it's like that on both sides. I replaced my sway bar mounts and end-links with an Energy Suspension kit to improve ride and handling. It worked great and wasn't very expensive.
    Check out if you're interested. I think AutoZone carries Energy Suspension parts also.
    If you want to see what it looks like, I have pictures of mine in my photo album on my profile.
    Hope that helps!
  3. ct9a
    Yeah, I don't have those things on either side of the bar. The truck feels fine when driving it, granted I don't go tearing around corners in the Suburban, but it seems ok. Is it possible that the previous owner removed them for a reason? What reason would that be?
  4. MrShorty
    Two reasons that come immediately to mind for removing sway bars:
    1) Bushings or other failed, causing a clunk. Remove bushings and end links and clunk goes away
    2) Sway bars limit suspension travel. Some remove swaybars to regain that extra little bit of suspension travel. I've removed the rear swaybar on my Suburban, but I don't yet dare remove the front sway bar. I've heard of some people/situations where the added suspension travel is enough to cause the CV joints to bind up.
    Probably other reasons, but those are the 1st two that come to mind.
  5. Jungle
    Jungle Member
    SInce you may spend a lot of money on your sway bar, you might consider upgrading to a HD swaybar like i did.
  6. Pete95Sierra
    he probably took it out for the suspension travel, which stinks with IFS anyway. most offroaders if there smart take out the sway bars cuz teh suspension flexes so much better with them out. however, on your burban, i would put one back in.
  7. zippy
    zippy Rockstar 100 Posts
    Yep, some off roaders disconnect their anit-sway bars for rough country situation wanting a more independent front end, and reconnect them to be legal for highway driving. There are even quick-disconnect bar end links. Perhaps the previous owner didn't want to part with his trick links when he sold the truck and removed them. You received the truck with an unanchored bar.
    My '93 'Burb eats bar end link rubber like it's free. I even changed the bar thinking there was something wrong with the OE bar. Perhaps the missing links have nothing to do with rough road mods but were an economy measure.
    It seems that every time I get a link repair kit, it's set for a different link height.
    IHMO, have a good suspension tech determine your link lengths so the geometry is correct.
  8. 95CTburb19
    95CTburb19 Epic Member 5+ Years 1000 Posts
    yeah I don't run front or rear swaybars on my jeep. It takes some getting used to on the road, I'll never get a speeding ticket in it thats for sure.
  9. ct9a
    I think I may just leave it as is. I've had it on the highway over 80 mph already and haven't had the slightest amount of instability. I am taking it to TX (from CO) this coming week and I don't have the cash to get new end links anyway.
    That being said, do I even need the thing on there? Can I completely remove it since it doesn't seem to be serving any purpose at all?
    ETA: Zippy, in the case that I decide to reconnect it, I am intrigued by the idea of the quick remove links. Do you have any links as to where to get these? Will removing and reinstalling them cause need for an alignment every time?
  10. zippy
    Don't have a clue, they talked about them on Extreme 4x4, and it seemed like an intriguing idea -- if they mentioned a brand, I don't recall.
    Out of curiosity, I just did a quick google and got a mess of hits. Ever hear of the SkyJackers brand? ;-)
    Here's their Jeep kit:
    The pic gives you an idea of the parts involved. Those snap clips look like the same thing I use on my tractor implements.
