Front Valance removal not the air damn the piece above it
Discussion in 'General Chevy & GM Tech Questions' started by Dand, May 16, 2012.
  1. Dand
    Dand New Member
    Greetings to all from Colorado! Need some help, I want to remove the front valance located right below the shinny chrome bumper, I stuck my hand up inside and felt the whatever's it is that holds it on. What do I need to get this thing off....Help Me Please!!!:sign0017:
  2. sstoner911
    Truck...year..maybe a pic....
  3. Dand
    Dand New Member
    It' a 06 Silverado what type of tool do I need for the nuts used to attach it
  4. UpsetProps
    UpsetProps Member 2 Years 100 Posts
    Pretty sure he means this piece pictured below, I don't own this body style anymore otherwise I would crawl under and check for you. Hopefully someone else can provide more info.
  5. Dand
    Dand New Member
    That's the piece alright! After crawling back under for a closer look I've found that it attached vis push pins (clamps) just as are the fender flares. By the way the push pins are 4 bucks a piece, there's' a male and and female. Oh yeh there's 13 of them.
  6. SurrealOne
    You might be able to get them cheaper at Lowes. I've seen a number of push pins in a cabinet of theirs ... going for far, far less than stealerships want.
  7. sstoner911
    Ya just pop the pin up with a small screw driver then pop the other part out.
  8. Dand
    Dand New Member
    Are talking about the center of the pin or what
  9. Cheez
    Cheez Rockstar 100 Posts
    If I remember correctly, the center (male) pulls out and then you have to squeeze 2 wings from the bottom to get the female part completely out. I took mine off a couple of months ago. It was an ordeal due to 8 years of dirt under there.
  10. rileyjr16
    Cheez is right but on mine, I got fed up with trying to get them off so I broke them all off and replaced them with Grade A bolts, flat, and lock washers and nuts.
