frozen washer fluid lines
Discussion in 'Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)' started by Ohio Tahoe, Dec 16, 2009.
  1. Ohio Tahoe
    Ohio Tahoe Member
    The line for the rear washer fluid appears to be frozen. The tank has been emptied. Then refilled with warm washer fluid. Front washer works fine, rear up works too. Just no fluid to the rear window. I do not have access to a garage to park inside.
    Any suggestions?
  2. Bill1996
    Bill1996 New Member
    You may want to check the nozzle itself maybe plugged with dirt,if you can also take line off see if you can blow on it,should be easy to blow on through, it if not its plugged
