FS: Powertrax Lock Right; GM 10 bolt 8.5" 30 spline
Discussion in 'General Classifieds' started by 04SilveradoMykk, Mar 23, 2009.
  1. 04SilveradoMykk
    04SilveradoMykk Rockstar 100 Posts
    Item: Powertrax Lock Right for GM 10 bolt 8.5" ring with 30 spline axles
    Condition: Used, installed in a carrier but never assembled completely or added gear oil. Removed due to wrong part for application
    This locker is perfect for you off-road enthusiast who want to get the most out of your 4x4. This locker is still street friendly but really shines out on the trail.
    This locker will come with the original installation instructions as well as the owners manual, it's an easy install without having to remove the carrier or reset ring gear / pinion backlash. Just remove the spider gears and install the lockers components one piece at a time into your factory open-diff carrier.
    Will not fit Gm 10 bolt 8.625" ring 30 spline axles, as I found out the hard way.
  2. Sierra23
    Sierra23 New Member
    where are you located?
