Fuel Cap
Discussion in 'Performance & Fuel' started by stinger44, Sep 7, 2011.
  1. stinger44
    stinger44 Rockstar
    DIC keeps displaying "tighten fuel cap" and my CEL keeps having to be reset. Do these caps go bad or is it the fuel neck the cap screws on to? Can't seem to find a definitive answer in here. Trying to re-tighten the cap isn't working.:grrrrrr:
  2. silveradotrailblazer
    Most likely its not the cap its the pain-in-the-as* evap system. I replaced mine and a year later same issues. I just turn the code off when it comes up. I also tried replacing the gas cap which didn't help.
  3. BillM
    BillM Rockstar 100 Posts
    SilveradoTrailblazer is probably correct. However, caps do go bad and it is part of the evap system which is smog control stuff. Smog stations check gas caps as part of the smog cert process in Calif. I bet auto parts stores can check your cap for free.
  4. tbplus10
    As noted the EVAP system has been known to cause this problem and the gaskets on the fuel caps have been known to go bad.
    The fuel cap is the cheapest item so you might want to start there, if that doesnt fix it start looking at any flexible hoses on the EVAP system.
  5. stinger44
    stinger44 Rockstar
    Fuel Cap and CEL
    Thanks folks, I appreciate the ideas. I'll start with the fuel cap even though it physically looks fine. It's a small inconvenience but and inconvenience anyway.
