Fuel gauge issues
Discussion in 'General Chevy & GM Tech Questions' started by RyDogZ71, Apr 18, 2010.
  1. RyDogZ71
    RyDogZ71 Member
    I have a 2000 Silverado 4.8, and my fuel gauge rarely indicates the correct fuel level. once i fill up it shows empty, and the low fuel light comes on. Any suggestions as to what the problem is?
  2. murdog94
    Fuel pump module. They were junk from the factory. The contacts on the intank module were easly corroded by gasoline...
    Sadly the only fix for this is to replace that module which means dropping your tank.
  3. yellowhusky
    yellowhusky New Member
    Fuel pump stopped working the other day (left me on the side of the road) and I had to drop the fuel tank and replace it. (the shop quoted me $650 and I did it for $150 !) This fixed the fuel guage too which hasnt worked in years.
  4. Loggerhead Mike
    the sender and fuel pump modules on those are seperate
    take the sender off the pump and pop the cap off. more than likely you'll see one of the wires in the sensor broken
    hook a DMM up to the sender connector and do a sweep test. you'll find your dead spot
  5. Silverado1500
    Silverado1500 Rockstar 100 Posts
    would this effect mpg? because i have the same thing with my truck and i am getting around 9-11mpg 5.3l
  6. yellowhusky
    I know this is an old thread, but as I said, I replaced the fuel pump/sending unit in 2010, and the fuel gauge has started acting hinkey again in 2014. Guess I'll have to revisit the unit and see if there is a better quality one out there.
  7. Pikey
    From what everyone says the airteck are garbage. You have to go ac delco or dlphi
