Fuel gauge needle
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by Treadnmud, Feb 5, 2012.
  1. Treadnmud
    Treadnmud New Member
    On my 99 Suburban, the fuel gauge needle appears to be vibrating and shakes rapidly back and forth about a needle's width or so. Some say it is most likely the sending unit. Comments?
  2. Naptime
    Naptime Rockstar 100 Posts
    Mine does it too. These gauge clusters fail after a while. Cheap DIY (but PITA) fix.
  3. vncj96
    Its the gauge cluster i replaced mine a few years ago (at a $300 cost) and mine is doing it again. So what its the cheap DIY fix please?
  4. Mysuburban99
    Mysuburban99 New Member
    Mine was doing the same thing replaced fuel pump and sending unit. Stopped it from jumping up and down.
  5. janikphoto
    janikphoto Rockstar 3 Years 100 Posts
    Mine has done it since I got the truck last fall. I would have to guess there is a resistor on the sending unit that must fail.
  6. KidHauler
    Mine too. The voltmeter bounces with the turn signals, too. If I remember right, it's the servo motors on the back of the cluster that go bad - I think there is a post on the site about where/how to replace them, but I won't have time to look until sometime tomorrow.
    Good luck to us all...
    The stepper motors on the back of the clusters go bad. My gas gauge stopped working completely last year, so I sent my cluster to some guy in Minnesota (through ebay) and for $60, he replaced all of the stepper motors, all of the cluster bulbs and updated the cluster with the newest software. Plus it came with a lifetime warranty, pretty good deal IMO.
  8. murdog94
    With the 95-99 suburbans usually it is the sending unit that goes out as the ground gets corroded in the tank. The stepper motors do fail in those years but usually it is the sending unit. to be honest if it doesnt bother you let it go till it isnt reading correctly since it requires that you drop the tank.
  9. vncj96
    In mine and other friends it has never been the sensing unit its always been the cluster/stepper motors that fail. [MENTION=33745]TELORVEHC[/MENTION] I suppose you still dont have an address or contact info for the guy in MN that you had replace the motors?
    This is the ebay seller that repaired my cluster---->http://stores.ebay.com/digitalspeedometerrepairservice and the address is 123 W. Sarnia Street, Winona, MN 55987.
