Fuel Pressure increase
Discussion in 'Chevy C/K Truck Forum' started by GMANs95, Nov 21, 2013.
  1. GMANs95
    GMANs95 Member 1 Year
    What is the best way to increase the fuel pressure to the TB? I have noticed now that when I get below a 1/4 tank it spits and sputters on acceleration. I have already considered a fuel pump knowing the nightmare it will be to change it. The truck has 200K plus on it and I am sure the pump is tired.
    I have seen some TBi mods the allow for increased pressure, but wanna hear from the powers herein.
    Its a 95 5.7l 2wd.
    What say Ye?
    :sign0011:
  2. RayVoy
    I doubt if you need more pressure, it sounds like you could be sucking in air.
    The pump pickup should be in a small "well" inside the tank. This "well" is an area that stays filled with fuel under hard braking, or, hard acceleration. In other words, the tanks are designed so that a small amount of fuel stays at the pickup, when the rest is pulled forward, or pushed rearward in the tank.
    You might have a tank problem (the little well has moved, or leaks), or, the pickup is too high in the tank, or, the pickup has a hole somewhere in the tube. I suspect the tank.
  3. GMANs95
    This well you speak of....is it "attached" to the tank some how....If so how can it move? As far as I know this is the original pump and hasn't been changed.
    just curious.
  4. RayVoy
    Yep, it's attached to the tank, just one of a number of baffles inside the tank that keeps the fuel from sloshing around when the vehicle is moving.
    [​IMG]
