fuel pump & tank
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by miller57, Jun 19, 2009.
  1. miller57
    miller57 Member
    just had a new fuel pump and tank installed in my 98 sub
    now i am getting a fuel smell in the cabin. I think i am also getting it in the engine compartment(hard to tell with fan blowing). Could there be a vent hose off? Didn't have the smell before the new pump
    any ideas???
    Thanks
    miller57
  2. redneckarmyMP
    redneckarmyMP Epic Member 5+ Years 500 Posts
    is your truck running any differently?
  3. Jimmiee
    Be careful if you have a fuel leak. Take it back to the shop and have them look at it. Sounds like an EVAP hose is leaking somewhere.
  4. miller57
    miller57 Member
    Truck is running better than before(smother)
    i filled it all the way up this morning and gas ran out out of the top of the tankall over the ground
    took it back to the shop and they said it must be the " o ring on the pump"
    i think its some kind of vent hose
    they said to run out the gas to 1/4 tank and they would redrop the tank and see where the leak is
  5. Bikeman
    Bikeman Member
    Do you smoke?
  6. iPublicEnemy47
    iPublicEnemy47 Rockstar 100 Posts
    I sure hope he doesnt
  7. L0sts0ul
    L0sts0ul Rockstar 100 Posts
    I agree with the possibility of the evap hose, however, check the connections at the fuel filter and do you see anything on the ground? try to locate a leak.
    If could also be in the top of the tank.
