Fuse problem, maybe
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by SOUP, Oct 19, 2009.
  1. SOUP
    SOUP New Member
    Went to get my service engine light read and I'm not getting any power to the quick connect for the computer under the dash. Guy said it runs on the same circuit as the cigarette lighter but I couldn't find any blown fuses. Does anyone have any suggestions maybe I was looking at the wrong set of fuses, If anyone could help please do. Thanks.
  2. Jimmiee
    Jimmiee New Member
    Ummm, what kind of a vehicle are we talking about??
  3. SOUP
    SOUP New Member
    My bad it's a 2002 Suburban LT
  4. Jimmiee
    Jimmiee New Member
    The first thing you want to do is verify with a volt meter that there is no voltage on pin 16 of your DLC <Data Link Connector> with the key on. If you do in fact have no power there then go to the cigar fuse in the power distribution box under the hood. Check this fuse. If it's good then you have to check the orange wire at pin 16 of the DLC back to the fuse. Check for aftermarket accessories like an alarm, stereo, amp, brake controller or anything under the dash. Techs like to tap into this orange wire. Does the cig lighter work? As a last resort you can jump 12 volts to pin 16 to get a scanner to work. Also, a bad or no ground at pin 4 of the dLC will cause a scanner not to work.
  5. SOUP
    SOUP New Member
    the cig lighter does not work, Im going to check these things out and get back with you. Thanks for the help.
  6. SOUP
    SOUP New Member
    Thanks for the help, it was the fuse, I was looking for a relay to be the problem.
  7. dwill3015
    dwill3015 New Member
    You're my hero Jimmie. You give alot of great Q&A advice here and it is very appreciated!
