gas problems
Discussion in 'Chevy C/K Truck Forum' started by slim2, Apr 7, 2014.
  1. slim2
    slim2 New Member
    I have a 1988 gmc sierra 3500 dump truck, with a 5.7 engine that does not want to rev up on a pull. Seems like not getting enough gas. I had put a new gas tank on and it ran great. I then purchased gas a few days later, and its been going down hill ever since. Dont know if the carburator has a filter built into it, or maybe i have an electrical problem. Truck just has no power. Anyone ever had that problem? Thanks for any help
  2. Rocketmanh5
    Did you check to see if possibly a rag or other material could be blocking the pickup in the tank?
  3. RayVoy
    Carburetors usually have a filter, there is also a gas filter that may need to be changed.
  4. JTWard
    JTWard Rockstar 3 Years 500 Posts
    I would see if the fuel pump is working both steady and that there isn't a leak internally, For that to happen, you oil level that appears on the dipstick would be unusually high, and of course, it would smell like gasoline.
    I'm assuming you have a mechanical fuel pump and not a electric pump, Your truck isn't a fuel injected model is it ?
  5. kbonanny
    kbonanny New Member
    In 1988 they came with bot TBI (Throttle Body Injection) or a Quadrajet. If you let me know which one you have I can give you sound advice on what to look for. The other item that stands out is this..Does the truck have catalytic converter(s)???? If you have a cat (or more than 1), you may have a restricted exhaust!! Remember...an engine is little more than a large air compressor. The more air you can get in & out of it is directly related to the amount of power it will make. Your description of "lack of revs" screams exhaust restriction..... Though a lot of 1 tons were still exempt at that time. I need more information!
    1 person likes this.
