gauges acting up
Discussion in 'General Chevy & GM Tech Questions' started by jtw79, Jul 17, 2010.
  1. jtw79
    jtw79 New Member
    Anyone have problems with their speedo and oil pressure gauge acting up. I have a 2004 silverado w/ 4.3L V6. Speedo will either be way high compared to actual speed or low, will reset most of the time when ignition is turned off and then restart truck. Oil gauge just reads low and will reset. I also had issues with the A/C Knob the other day, it would only work on setting 4 and no others then it started working after some time. Thanks in advance.
  2. 99'HEARTBEAT
    The 2003"-2005".....Truck & SUV's have Problems with Gauges that Stick,Flutter and become Inoperative.......
    G.M. has a Special Coverage Adjustment for Trucks & SUV's.......the Coverage is for 7 years or 70,000.....in which G.M. will replace the Dash Cluster's....
    The Below link goes into detail re-guarding this,
    http://www.gmspeedometerrecall.com/
    If your truck is over on the Years & Mileage,there are company's that can fix your Dash Cluster.....the item that is causing the problem's with your Gauge's is the stepper motor...and that's the item that needs to be Replaced.
  3. murdog94
    X2!!! a lot of people on here have had that problem.
  4. Sportclmb
    Sportclmb New Member
    I've got a similar issue with my speedo. Going to replace the stepper motors as soon as I get them in. (ordered them off EBAY) I'll post how difficult/easy the change is.
  5. verne
    verne New Member
    My 2005 / 2500 HD did the same thing. Finally, speedo died together. Cost me almost $ 600 to replace at dealer. GM will cover if mileage under 70,000 in some cases. Am really fed up with Chevy's service!
  6. Sportclmb
    Just completed the change out of the stepper motors. It was incredibly simple if you know how to use a de-soldering tool and a soldering gun. Cost me a total of 40$ to change all the stepper motors out. And only tool about an hour. Dealer wanted 450.00 to fix.
  7. Springthing
    For those looking to go the stepper motor route - I do believe there is a post in the How-To section on doing just that.
  8. GLOCKIN101
    GLOCKIN101 New Member
    Southern Electronics distributors in Tucker Ga,(770 270 97400)They will fix it,send it to them,About $175
  9. ibmoses
    ibmoses Rockstar 100 Posts
  10. GLOCKIN101
    Thats not bad,I will check them out
    ---------- Post added at 07:44 PM ---------- Previous post was at 06:56 PM ----------
    Whent out to my 04 tahoe last night to do the put it in drive and turn the key trick to reset the gages it worked on all but the speedo,Now my tahoe is real hard to crank i think it fiooded it with the fuel pump coming on and off so many times,i turned it on and off about 4 times,it was hard to crank yesterday and today,would not do this trick,just pull the fuse and put it back in,If any one knows why my tahoe is hard to crank please let me know,I even drove it around a little yesterday and it stiil was hard to crank today
    ---------- Post added at 07:45 PM ---------- Previous post was at 07:44 PM ----------
