gm leak tabs on 5.7 intake manifold leak
Discussion in 'General Chevy & GM Tech Questions' started by raceville, Jan 13, 2011.
  1. raceville
    raceville New Member
    Hello, I wanted to know if I could use the GM stop leak tabs on 5.7 intake manifold leak.
    Just untill it warms up outside to do the job right with the new gasket.
    Thankyou Raceville
  2. murdog94
    I wouldnt reccomend using any type of stop leak, since it is a get you home method, that over time can clog up your radiator, and heater core, and just leave behind a lot of junk in the coolant passages, that you dont want. Also when you change your intake gaskets use green coolant instead of dexcool.
