GM vehicles with AFM
Discussion in 'Performance & Fuel' started by My99Silverado, Nov 19, 2012.
  1. My99Silverado
    My99Silverado New Member
    I am looking for a couple people with relatively unmodified GM trucks with AFM to test out a new product that will increase your gas mileage. Here is a link to the product www.rangetechnology.com. Basically what it does is put increase the amount of time spent in 4 cylinder mode.
    All that is needed is 5-10 people willing to test out the product and get the word out there by writing reviews/giving feedback. No cost to you.
    PM me if you are interested.
  2. RayVoy
    Ok, I might be interested; however, it sounds like it is a modification to the tables/parms within the PCM flash. Rumour, on the street, is that GM has the ability to detect a PCM re-flash and can void the warranty if detected. Can you comment?
  3. My99Silverado
    I am not with the company, I am just one of you guys but I was in contact with one of the owners of the new product who asked me to find 5-10 other people to test the product and give feedback. I voiced your concern to him and he replied "We do not reflash. It is all done via messages on the CAN. 100% undetectable. Also - we have some dealers that are interested in the product."
  4. dobey
    And when should one expect to see a reply to the PM or to an e-mail sent to Adam as he requested in the other post on the "how to increase MPG" thread?
  5. RayVoy
    As I said above, I'm interested, but my main concern is around the time spent in 4 cylinder mode. There are some concerns that the block will heat unevenly while in 4 cylinder, prolonging that period may cause some problems. Just my 2 cents.
  6. dobey
    Given how the AFM cylinders are spread across the V8 engines, I suspect this is just a baseless fear. As long as the cylinders continue to recieve proper oiling, there shouldn't be an issue.
  7. ChevyBoy2009
    ChevyBoy2009 Rockstar 4 Years 500 Posts
  8. RayVoy
    Actually, it appears to be a real problem. A lot of speculation that the uneven heating/cooling is contributing to the higher than normal oil consumption in these engines.
  9. dobey
    Is it a real problem, or is it speculation? It can't be both. People have been complaining about "higher than normal" oil consumption on the LS series since it was introduced in 1997, in one form or another. So it's very hard to guess at what the problem may be for whoever you say is complaining about it. Do you have links to hard evidence about uneven heating, and/or oil consumption, or are you just passing on the hearsay?
  10. RayVoy
    I believe I said "it appears to be a problem". I'm not looking for an argument, you however appear (using your 1st post on this thread as reference) to have a little bit of an attitude with this product, or the supplier. GM's programming forces V4 back to V8 with very little load difference we need to ask why. Is it because load, even a small load, causes heat, and is GM worried about too much heat if the engine stays in V4.
    Again, I'm not looking for a debate, my apologies to the OP.
